Hi mhld,
I don't know your LC version, anyway in version 2
Is there a way to move the dimension numbers *without* moving the dimension line?
TO MOVE THE DIMENSION NUMBER:
As you maybe already know you can change the text offset in Edit>Current Drawing Preferences> Dimensions> Dimension line gap. Anyway:
- You have a dimension (pic 1)
- Select the dimension, now it will appear dashed and its color will change (pic 2)
- Just move the blue dot by clicking on it and keeping clicked, so you'll move the dimension's number! (pic 3)
0r is there a way to delete the leading "0." manually?
TO CLEAR "0.VALUE"
1
- Be sure that TOOL OPTIONS bar is active (if not: right click randomly on a free area on horizontal bars and activate Tool option)
- Click on dimensions icon and choose horizontal/vertical and so on...
- A menu on the tool options bar will appear containing a LABEL icon. (pic A)
- Here you can change the dimension (you can even write a text!), and you should be satisfied now! (pic B)
- In your case I changed from 100 to .10 to show the result. I had to turn the grid off to make the picture more readable (pic C)
2: If you have already given the dimension:
- Simply go to Modify>Edit Entity eometry, click on the dimension that has to be modified
- In "Label"insert the value that you need and that's all! (pic D)
So... Actually you can have both of your requests satisfied!
I hope I have been useful!
Bye!!!
Cla
