Under OPTIONS : CURRENT DRAWING PREFERENCES : DIMENSIONS :LENGTH FACTOR. If that number is anything other than 1 LibreCAD will scale the drawing by that factor when dimensioning your drawing. Likewise, if you're using different units and grid settings than what you think, you may get an unexpected number when dimensioning. ie You set the grid to be .125" spacing but then you draw as if 10 grid units is 1".
