drawing (and moving...) by typing line-length
Coiske60
Hallo, i'm a newbe in LibreCad, and coming from AutoCad (that I can't afford anymore) it's a very nice 2D program.
I just found the command line, so I can start drawing with precision.
However, there is a feature with Autocad I thought to be very time-saving: drawing a line or moving/copying an object by indicating :
-the start point,
-the direction (by using constraint) and
-the wanted length/distance
As far as  I know, I have to do this in Librecad by clicking the start point and then giving the relative coordinates of the endpoint, which is more time consuming.
(In Autocad I even used this feature  by drawing first the dimensions as a reference for the actual drawing afterwards.)
Does this feature exist in LC, and if not it should be nice to add it.
Thanks for any answer, and can I do this suggestion somewhere?
Re: drawing (and moving...) by typing line-length
This feature does not exist in LibreCAD, it has been asked for several times. I would not expect this to be implemented in foreseeable future, as there is no one to do it.
Coiske60
ok, so be it.  Drawing and moving  with "@[length]<[angle]" is nearly as good.
Felicitations anyway for all the efforts. Librecad is just fine.  I can draw all I want in 2D.
and thanks for the answer
Op zo 27 okt. 2019 om 20:32 schreef dellus [via LibreCAD] <[hidden email]>:
https://forum.librecad.org/drawing-and-moving-by-typing-line-length-tp5717820p5717883.html
To unsubscribe from drawing (and moving...) by typing line-length, click here.
François Versbraegen
Koningslosesteenweg 73
1853 Strombeek
Tel (32) 02 267 9121
GSM (32) 0472 49 81 47
Email: [hidden email]
Lexy
In reply to this post by Coiske60
I am wondering if there is any change in this subject/question? maybe we can make a request somewhere?
kind regards
Not exactly what is asked for, but something similar: https://forum.librecad.org/User-Manual-tp5716605.html
