dwg support?
13 messages Options Options
lj
dwg support?
lj
Installed Librecad as it was listed as a Linux Mint alternative to allow viewing & converting dwg files, but dwg was not an option when I tried to open a dwg file after install (which went fine otherwise as far as I can tell).  No updates apparently available through synaptic package manager or update manager.  Suggestions?
Re: dwg support?
dwg support is only in the latest 2.08 edition or the nightly builds. It's still experimental, only import and it doesn't open all dwg-files. For linux try the Teigha file converter / viewer ( please google for it ). It works well for me in puppylinux.
lj
Re: dwg support?
lj
Thanks, Dellus.  Found Teigha with deb installer & will see if it works with Mint 17.2.
http://forum.librecad.org/dwg-support-tp5712232p5712235.html
To unsubscribe from dwg support?, click here.
Re: dwg support?
Hi dellus,
In latest code I solve 6 bugs opening dwg but, if you can't open some dwg, please send it (here or for private) and I can investigate the problem.
Cheers,
Re: dwg support?
Hi Rallaz,
here is a dwg that didn't open, the pc hung. Another one from the same source also didn't work. It seems to contain some layout stuff. It is quite big though there is not much in the drawing. It opened in draftsight without problems. No need for me, but if you like you can investigate. 150216_ACB_Halle_Bruha.dwg
Re: dwg support?
Hi dellus,
Your attached dwg file fails in 2.0.8 but works with the last patches.
I used to test this windows build:
http://sourceforge.net/projects/librecad/files/Windows/NightlyBuilds/2.0/LibreCAD-Installer-2.0.8-20-g5b004c1.exe/download
And the proof:
Cheers,
Re: dwg support?
Success confirmed. Well done, Rallaz. Isn't this a candidate for a main bugfix 2.0.8.1 release, not to disappoint new customers? Master branch seems not to have this. Can i install the windows nightlies of master and of 2.0 in parallel, without spoiling something? 2.0.8 standard i have installed as portable from portableapps.com.
Regards dellus
Re: dwg support?
one easy way is to provide a 2.0-nightly installers.
I suppose Armin can easily add this for win32.
For OS/X, we don't even have the resource (developer time, and hardware/bandwidth) to maintain master nightly build.
Any help is welcome!
Regards dellus
Re: dwg support?
Hi dellus,
Dwg patches are in both 2.0 & master branch.
2.0 branch nightly builds:
master branch nightly builds:
http://sourceforge.net/projects/librecad/files/Windows/NightlyBuilds/master/
Re: dwg support?
Hi Rallaz,
just for feedback:
that file which didn't open formerly and now does, in the latest win nightly 2.0.8...fa5e shows objects with wrong angle (diagonally).
In the master branch 2.0.7...889b it still doesn't open at all, allthough you said the dwg-fixes are there as well.
regards dellus
Re: dwg support?
Hi dellus,
Sorry for the delay, I am very busy.
The master branch is the same as 2.0 branch plus code to work with MSVC.
I found a bug in the MSVC code and send a patch you can test it in a 2 october or later build.
Cheers,
Re: dwg support?
About wrong angle in 2.0.8 brach is another new bug not related with dwg files.
Text and inserts are good read and saved but displayed with a bad angle. I opened a bug report reporting the problem.
Re: dwg support?
librecaduser
Hello:
Just download LibreCAD.
"Version: 2.1.1
Compiler: GNU GCC 4.9.1
Compiled on: Jun 25 2016
Qt Version: 5.4.1
Boost Version: 1.60.0
System: Windows "
I have an error with dwg file.
Here is the message:
Opened dwg file version dwg version 2013.
error reading blocks in dwg file
Cannot open the file
What to do now?
Thank you.
