dxf file is saved in vectorworks, I can open in librecad but is empty screen
2 messages Options Options
ebocek1
1 post
Hello all,
I'm a new librecad user and I have the following issue.
A friend made a plan in vectorworks and saved as dxf file 1.673 KB. I can open this in librecad and the command line says loaded document: C:\Users\bocek.erdinc\Downloads\Böcek Koersel 030421.dxf
So no errors.
But the screen is empty (see attachment)
I tried auto zoom, doesn't help
I tried to save but then the size is just 23KB
I also tried to open recent files, doesn't work
Has anybody got an idea what more I can try to open this file?
Thanks in advance for your supports and ideas
grts
Re: dxf file is saved in vectorworks, I can open in librecad but is empty screen
Hard to say without the file.
 Maybe it is not compatible with LibreCAD. Too new version? LibreCAD supports up to dxf 2007.
 3-D file? Does it open in other CADs apart from vectorworks? Does Tool - Select - Select All show anything? Layers off? Does it contain images?
If you like to share the file here you can zip it to make it smaller.
Edit: maybe a binary file? ASCII less troublesome.
