Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on Apr 22, 2013; 1:43pm.
Hi, I've done this little project to add in the next release of LC, just like sample, you knowm many programs add example files, so I thought "why not LC?".
If you think it takes too man Mb in the compiled file, no problem, then we could create a section here in the forum called "examples" or "samples" (maybe you have alredy created it and I did not find it!!!) Anyway... here (I REMOVED IT, PLEASE LOOK DOWN) and obviousely a pdf version too (I REMOVED IT, PLEASE LOOK DOWN) Obviousely is not an awesome project, but the aim is showing the possibilities of LC, I hope this will help... Bye friends!
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Excellent!!! I tried to study pdf carefully. Noticed that in "Map" top window has been "Dimensioned"; to be read from left. As per my understanding drawing is to read from bottom or from right. If you agree, correct it. On opening it in LibreCAD 1.0.2, I noticed these dimensions almost horizontal. On checking, I found angle is 15469.9; which is strange. See attached screenshot. However, LC 2.0 Beta, show it 270. IMO opinion it should be 90; and also give some good name to it ;-) ![]() To me, it is awesome. If you make its tutorial, "How to make a House" will be wonderful. Bye
H.S.Rai |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on Apr 22, 2013; 7:05am.
Hi My friend...
1) That is strange... I use LC 2.0 beta1 and dimensions are horiziontal and vertical with this version; and the angle dimension is 30° (I had to explode the angle dimension, so it is a text). I cannot imagine what is wrong with the other dimensions. Anyway I attach a picture... ![]() 2)Here in Italy we use this kind of dimensioning! So this is correct here, well, I obviousely can modify... ![]() 3) To be honest, this was born as a tutorial, but the video was 1.4 Gb just for drawing the map!!! So I could never upload this ![]() ![]() Claus
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Personally I dislike video tutorials for many reasons. a) Size b) Language (assent) issue. People from A country find it difficult to understand English spoken by people from country B. I like text tutorial along with illustrations (images). See, if you can do that.
H.S.Rai |
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
"...I've done this little project to add in the next release of LC, just like sample..."
Dude, this is nice. I think LC definitively does need a library such QCad did (does). Maybe someone can rename "Useful library symbols and blocks" to "Useful library symbols and blocks and examples". http://forum.librecad.org/Useful-library-symbols-and-blocks-f5707181.html Or it would be even better to also rename "LibreCAD user - Tips and Tricks/Library blocks" to "LibreCAD user - Tips and Tricks/Library blocks/Examples" |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on Apr 22, 2013; 2:03pm.
In reply to this post by hsrai
Ok,
@hsrai: dear hsrai, I will see what I can do, and I understood what you meant before with the dimensions' orientation... so I re-uploaded the corrected files, here: Example.pdf and DXF Example.dxf @onone: well my friend... I think we should cooperate as much as we can; I am not a mechanical designer, nor a programmer, moreover I saw that the manual has been handled by another good friend, so even if I (should) work in building sector, I am trying to give my little contribution as I am able to do... As you can see I did not draw a beautiful house intentionally because design is my proper work, but the LC features are -in my opinion- shown, so that if someone is trying to find excuses or justifications to say that closed sources programs are the only ones to use, he/she must change his/her mind... See ya! (and pray for my country... damned politicians ![]()
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
In reply to this post by onone
Here is a damn simple from my side: PDF: pattern.pdf DXF (2007 version): Pattern.dxf ![]()
H.S.Rai |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Nice work hsrai!!! More art than CAD drawing... eheheh!
See ya!
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
>>DXF (2007 version):
>>Pattern.dxf AutoCAD can not load this file. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
On Wed, Apr 24, 2013 at 1:24 AM, zamtmn [via LibreCAD]
<[hidden email]> wrote: >>>DXF (2007 version): >>>Pattern.dxf > AutoCAD can not load this file. @ Developers Should be treat it as some bug? -- Prof. (Dr.) H.S.Rai Dean Testing and Consultancy http://gndec.ac.in/tcc/ Guru Nanak Dev Engg. College http://gndec.ac.in/ Ludhiana (Pb) India http://gndec.ac.in/~hsrai/ http://hs.raiandrai.com = = = = = = = = = = = = Please consider your environmental responsibility before printing this e-mail - Save paper
H.S.Rai |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on May 08, 2013; 10:15am.
@ hsrai:
You persuaded me and I am working on the tutorial ![]() Here I give you the stuff I prepared so far, give me some advice if you have any (example: if I am not explaining well something) (I REMOVED IT, PLEASE LOOK DOWN, GET THE ENTIRE TUTORIAL!) Have a nice sunday! Claus
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
On Sun, Apr 28, 2013 at 8:10 PM, claus82 [via LibreCAD]
<[hidden email]> wrote: > > @ hsrai: > > You persuaded me and I am working on the tutorial Great!!! > I am not a good teacher Please never say that. Rather say: "I am the best teacher". Whatever you say, you become that ;-) > but I am doing the best I can. I prepared 7 at pages so far... Nice. > I hope soon I'll finish the rest of the tutorial (that will be posted > in .pdf and .odt formats)! Waiting for that. All the best. With regards, -- H.S.Rai
H.S.Rai |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on May 08, 2013; 10:10am.
Hi, unfortunately Libreoffice gave me a lot of problem, so I had to do again the tutorial, up to now that is what I've done,
(I REMOVED IT, PLEASE LOOK DOWN, GET THE ENTIRE TUTORIAL!) I can say that I think I'm not far from the finish... I think other 5 or 6 pages... See ya! Claus
Loading... |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
1 post
I suck in English but I think I found some typos.
p.3 ecc probalby Current p.4 prorpieties layer lie types p.5 then then type draw a rectangles righ corner and cop the kitchen the others rectangles p.6 and to to the so you sold add vertica of 30 endpoint t the p.7 .give linving room p.9 :) mus have higer than higer than p.11 mirrir objects Thanks for the tutorial. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Sad to know that you need to redo it :-( What happened to LibreOffice? You may give Google Doc / Drive a try. We can comment there and if you allow we can edit also. Complete revision system is there in place. If you don't like others' edit, you may roll back. Hey man, you are doing a good job, keep it up; we are going to have a good tutorial.
H.S.Rai |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
hi, I also think google doc/drive is a good idea here. Thanks, Dongxu On Sun, May 5, 2013 at 12:56 PM, hsrai [via LibreCAD] <[hidden email]> wrote: Sad to know that you need to redo it :-( ... [show rest of quote] Dongxu Li, Ph.D. www.librecad.org |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
We need to have a 'central' place to keep user created tutorials like this and so I have changed the details of the 'LibreCAD Manual/Wiki topics' to reflect this! It now is called - LibreCAD Tutorials and Manual/Wiki topics. Possibly we could also add these tutorials to the wiki. @claus, great job with your tutorial, it would be good to post it into the above forum. |
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on May 08, 2013; 10:08am.
@ ALL:
I don't know what happened to Libreoffice, honestly it's quite demotivating, but finally I was able to redo the tutorial! Here I put the finished PDF, as soon as I can I'll post the .odt format too! @ Ratchet: you can do whateve you need ![]() I almost forgot it!!! Here the entire tutorial (I REMOVED IT, PLEASE LOOK DOWN) Please check it! I already checked it, but this trouble with Libreoffice leaves me some dubt See ya!!!!!!!!! ![]()
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
This post was updated on May 24, 2013; 4:55pm.
It seems that I fixed the situation.
Well, here the tutorial, a bit more corrected! (LOOK AT PAGE 2!) down here the Example (LOOK AT PAGE 2!) Fine, I am waiting for your comments and suggestions! See ya! ![]()
Loading... |
Reply to author |
Edit post |
Move post |
Delete this post |
Change post date |
Print post |
Permalink |
Raw mail |
Nice job claus my friend with your tutorial, maybe you can add it to the wiki?
