export config parameters to another computer
GrcJct
Hey,
I need to work on 2 PC (Windows, sorry !).
On PC 1, I configure my Librecad to my tastes.
From time to time I will need to work on PC 2.
I would like to export the Librecad configuration parameters from PC 1 to PC 2.
Is there a way ? from file ? from registry ?
Thanks
Re: export config parameters to another computer
You should mention which version(s) of Windows and LibreCad you are using.
Check:
* settings in: C:\Users\User\AppData\Roaming\LibreCAD
* Application-preferences directories: https://librecad.readthedocs.io/en/latest/getstart/configure.html#application-preferences (maybe under C:\Program Files (x86)\LibreCAD)
You might prefer a PortableApp version:
* https://portableapps.com/apps/graphics_pictures/librecad-portable
* https://portableapps.com/node/61725
GrcJct
Thanks,
Windows 7 (and W10) and Librecad 2.1.3
That's funny because I checked Appsdata\local (only a file (librecad.alias), no Librecad directory under Appdata\Roaming and no Librecad directory under C:\ProgramData.
I had a check on the registry (current user) and it seems to be there
I export this part of the registry, apply it to computer 2 and works fine
