file that crushes my mac librecad
lapushkazaika
I created this file 2007 dxf on my pc computer.
But when i tried to open it on my mac version it crashes.
Drawing in vmware now :)
https://drive.google.com/file/d/0B0lZDcCAoZyhYVh1TmpkbFRfMlNIOUxFaTNSZm9ZeE5hYW0w/edit?usp=sharing
Re: file that crushes my mac librecad
lapushkazaika
9 jan 2014, 2.0.2 version
it opens here smoothly, from both DMG and MacPorts version.
Can you install librecad by MacPorts, if you are current using our DMG installer?
lapushkazaika
Updated os x to mavericks, installed macports, but "sudo port install librecad" failed with:
tail /opt/local/var/macports/logs/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_muparser/muparser/main.log wrote
:debug:extract Executing command line:  cd "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_muparser/muparser/work" && /usr/bin/gzip -dc '/opt/local/var/macports/distfiles/muparser/muparser_v132.tar.gz' | /usr/bin/gnutar --no-same-owner -xf -
:info:extract sh: /usr/bin/gnutar: No such file or directory
:info:extract gzip: error writing to output: Broken pipe
:info:extract gzip: /opt/local/var/macports/distfiles/muparser/muparser_v132.tar.gz: uncompress failed
:info:extract Command failed:  cd "/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_math_muparser/muparser/work" && /usr/bin/gzip -dc '/opt/local/var/macports/distfiles/muparser/muparser_v132.tar.gz' | /usr/bin/gnutar --no-same-owner -xf -
:info:extract Exit code: 127
:error:extract org.macports.extract for port muparser returned: command execution failed
:debug:extract Error code: NONE
:debug:extract Backtrace: command execution failed
    while executing
"$procedure $targetname"
:info:extract Warning: targets not executed for muparser: org.macports.activate org.macports.extract org.macports.patch org.macports.configure org.macports.build org.macports.destroot org.macports.install
Previously i downloaded LibreCAD-MountainLion.dmg, doubleclicked on it and drag-n-dropped icon labeled "LibreCAD" to Applications on my dashboard.
lapushkazaika
Ow, ports installer uninstalled librecad and then as i realized dod not installed from ports. But application in Applications folder is still there, run and opens my file!
In reply to this post by lapushkazaika
