When drawing a dimension line for architektural purposes I set the dimension line extension to "fixed", as is the habit there. This possibility was introduced in 2.08 and worked there. In later nightlies and 2.09 it didn't any more. You can set it in the configuration tab but it is not shown in the drawing properly, as if not set. I have added a picture of as it appears in a newer nightly (as is) and in 2.08 (should be). The should be regards the extension line only, zero suppression is better in the newer version. Also added picture of settings tab and example dxf.
OK, I will use a GitHub account for issues next time. And for suggestions "suggestions and feedback" in the forum, right?
Regards dellus
arch_cm_100_a3_uebung.dxf
