import from external sheets, .dwg from Auto Cad, not possible
5 messages Options Options
jan88
Dear librecsd team,
Interim i treat different drawings wich external generated.
In the actually Version i can´t open this sheet.
in a older Version 2.0.8-99  i can open the external sheet, generated from AutoCAD.
perhaps you can about a solution. Thanks!
Best Regards
Jan
Re: import from external sheets, .dwg from Auto Cad, not possible
Jan, to find a solution for your problem it is required to have one or more of the DWG files which don't open.
You can upload them here within a reply if public sharing is not a problem (see More->Upload a file).
Otherwise you can use the "Send mail to ..." function in my profile to get in touch by private mail.
jan88
In reply to this post by jan88
2161209_Falquon_AutoCAD2007.dwgHalle_-_Kopie.dwg
Falquon-Grundriß.dwg
Good Morning Sir & nice to read  you and your news.
...attached some sheets from different sender  for testing.
how i refered in version 2.08.-99 from december 2015 i can open this sheets,
but the performance for treatment and revision is to low.
with Version 2.1.0 and 2.1.3 i can´t open and get the onscreen message.
best regards
jan
jan88
jan88
.....good morning,
i used the  free " Any  dwg dxf converter " , after that i can open my Sheets.
Best Regards.jan
