libreCAD window doesn´t open
5 messages Options Options
pichler2860
i started libreCAD
the prog open but i see no start-window
on the task-bar there is the icon and when i hover it there is also the thumbnail picture
whats the problem?
Re: libreCAD window doesn´t open
Which version is this?
I suggest you to try another version.
It helps the troubleshooting process.
pichler2860
version: 2.0.0 beta1
last week i work with no problems!
For better help, always say what is your system and which librecad version you use.
This seems a bad "position and window size" saved settings
In linux delete or rename LibreCAD.conf in /home/"user"/.config/LibreCAD/
In windows exec regedit and find LibreCAD, then delete the "Geometry" branch.
bsorviz
Muchas gracias.
Esto es lo que a mí me ha pasado y borrando dicho registro, funciona perfectamente.
