no entity found
no entity found
bicykler
Yesterday I downloaded librecad on a mac mini with OS X 10.10.5.  I can draw simple objects but when I try to modify them i'm asked to select an entity but when do I get the message"no entity found".  I tried the same commands on a windows pc with good results.
Re: no entity found
which version of librecad?
Can you try to build from MacPorts?
Re: no entity found
bicykler
I have version 2.0.7 installed.  I see there is a .8 for windows, is it available for mac?  I'm fairly new to mac so I have never used macports but i will give it a try.
Re: no entity found
For Mac, all installers before 2.0.8 have packaging problems.
Please try the 2.0.8 https://github.com/LibreCAD/LibreCAD/releases/tag/2.0.8
I expect it run normally there for OSX 10.8 - 10.10, but if you continue to experience stability trouble, please install librecad by MacPorts:
http://wiki.librecad.org/index.php/LibreCAD_Installation_from_Source#LibreCAD_in_MacPorts
