Hi community,
I just cloned the repository, followed the homebrew install instructions in OSX, and tried to compile . The following is the very first warning and the first error message that followed. Any help is appreciated.... thanks.... ======================================================= g++ -c -pipe -g -O2 -Wall -W -fPIC -DQT_NO_DEBUG -I../../mkspec/macports -I. -I/usr/local/Cellar/qt/4.8.7/include -I../../generated/lib/libdxfrw/moc -o ../../generated/lib/libdxfrw/obj/libdwgr.o src/libdwgr.cpp In file included from src/dl_writer_ascii.cpp:34: src/dl_exception.h:51:9: warning: private field 'groupCode' is not used [-Wunused-private-field] int groupCode; ^ 1 warning generated. g++ -c -pipe -g -std=c++11 -O2 -Wall -W -fPIC -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_SHARED -I../../mkspec/macports -I. -I/usr/local/Cellar/qt/4.8.7/lib/QtSvg.framework/Versions/4/Headers -I/usr/local/Cellar/qt/4.8.7/lib/QtSvg.framework/Versions/4/Headers -I/usr/local/Cellar/qt/4.8.7/include -I../../generated/lib/jwwlib/moc -F/usr/local/Cellar/qt/4.8.7/lib -o ../../generated/lib/jwwlib/obj/dl_jww.o src/dl_jww.cpp src/muParserTokenReader.cpp:151:10: error: no member named 'unique_ptr' in namespace 'std' std::unique_ptr<ParserTokenReader> ptr(new ParserTokenReader(*this)); ~~~~~^ |
Hi dreylago,
Just double checked: the MuParser code is correct with <memory> header for unique_ptr You compiling command contains -std=c++11 I'm lost here, if the compiler is too old: g++-4.6 or earlier, -std=c++11 should have been rejected. still, what's your gcc version? g++ -v
$ g++ -v
Using built-in specs. COLLECT_GCC=g++ Target: x86_64-apple-darwin13.4.0 Configured with: ../configure --build=x86_64-apple-darwin13.4.0 --prefix=/usr/local/Cellar/gcc48/4.8.4 --libdir=/usr/local/Cellar/gcc48/4.8.4/lib/gcc/4.8 --enable-languages=c,c++,objc,obj-c++ --program-suffix=-4.8 --with-gmp=/usr/local/opt/gmp4 --with-mpfr=/usr/local/opt/mpfr2 --with-mpc=/usr/local/opt/libmpc08 --with-cloog=/usr/local/opt/cloog018 --with-isl=/usr/local/opt/isl011 --with-system-zlib --enable-libstdcxx-time=yes --enable-stage1-checking --enable-checking=release --enable-lto --disable-werror --with-pkgversion='Homebrew gcc48 4.8.4' --with-bugurl=https://github.com/Homebrew/homebrew-versions/issues --enable-plugin --disable-nls --enable-multilib Thread model: posix gcc version 4.8.4 (Homebrew gcc48 4.8.4) I am also confused by this... as the flags and version seem correct. |
One thing:
your gcc is at : /usr/local/ if it's not by MacPorts, could you try gcc from MacPorts?
Is it ok to mix homebrew with MacPorts gcc? my gcc was installed with homebrew. Should I uninstall it first?
Thanks |
just try any other (newer) gcc
You can also download Qt-5 (the latest version) and use clang comes with it.
