polilinea
polilinea
rob-1
hello i try to learn the polilinea
 but i  only make line straight,
 if i wont to make an  arc  after the line
with polilinea what is it the process?
Re: polilinea
Look at the tool options tool bar, it's above the drawing area.
When the polyline tool is active, you have additional items there to change between line and arc and other options.
See https://librecad.readthedocs.io/en/latest/ref/tools.html#polyline
But sometimes it may be easier to build a contour with lines and arcs and then create a polyline from existing segments. This is the last tool in the polyline menu.
It is important, that the segment endpoints match exactly, otherwise the tool doesn't work correct.
You can use the command line for exact coordinates or use valid snap modes to achieve this.
