As a model railroader I want to print 1:1 structure drawings into the H0 scale 1:87.
When I use the print preview I see numerous pre-defined scales like 1:75 or 1:100 etc.
These all work fine with the fixed-scale option.
But setting the scale to 1:87 (or any other not predefined scale) with the fixed-scale option does not result in the wanted scale. In stead, it seems to be rounded towards the next higher pre-defined scale.
Is this a bug, an omission or do I make some mistake?
By the way, model railroaders often use 1:25, 1:33, 1:44; 1:87, 1:90, 1.120, 1.220 scales!
Any suggestions on how to solve this problem will be more than welcome.
