scripting feature
8 messages Options
scripting feature
davinder
I would like to add scripting feature in librecad.
@all can you suggest me requirement for that, what is the eligibility
for that, documentation, books, language and any other stuff. If we
are able to add scripting feature in librecad, then it will be the
great achievement for librecad.
http://davinder.in
Dont hurt the web, use open standards
Re: scripting feature
hsrai
R. van Twisk wrote
some of the scripting code is available within LibreCAD as source,
but it's not enabled. This is the original source that can with QCad,
As for as my awareness was:
scripting feature is not there in community edition of QCAD.
If it is there, then how to enable it?
@ Davinder
Download source code, compile it as such.
If you are successful in compiling, then explore code and look for scripting module. Find way to enable it during compilation; may be documented in Installation Guide. If not, narrate your experience and raise question here.
Someone will come forward to help you.
Good to know that you are ready to contribute to this excellent software which is available in many languages.
H.S.Rai
H.S.Rai
davinder
In reply to this post by hsrai
@all i am successful in compiling the librecad from the source. Now i want to enable scripting feature in librecad while compiling.
How can i do that? What is the requirement for that?
Thanks in advance.
davinder
@Rallaz getting no response about how to add scripting feature in librecad.
@all where can i check the to do lists for librecad?
ClaudeQC
Hello davinder,
On 11/09/2011 20:38, davinder [via LibreCAD] wrote:
 > @all where can i check the to do lists for librecad?
- See links below:
        - Bugs to fix:
        - Features requests:
Claude
