settings in inches, but drawing displays only in m
3 messages Options Options
zaphead
Hi folks, I have the drawing and application settings both configured to use inches, however the drawing is displaying dimensions in m. I created the drawing shapes in inches and the conversion to m is correct, but I want the drawing to dimensions to display inches and I'm not sure what else to do.
I'm using M1 mac and LibreCad info:
Version: 2.2.0
Compiler: Clang 13.0.0
Compiled on: Dec 17 2022
Qt Version: 5.15.7
Boost Version: 1.80.0
System: macOS 12.6
Sincerely,
Ben
Re: settings in inches, but drawing displays only in m
EmmyToy
LibreCAD provides settings for both drawing units and display units.
Open LibreCAD and go to Edit - Drawing Settings - Drawing Options - General tab - Drawing Units make sure you select "Inches" as the unit of measure.
Then go to the Display tab in the Drawing Options dialog - Display Units section make sure you also select Inches as the unit - OK to save the changes.
After making these changes, the picture should be displayed in inches, according to your settings.
instruction page Drawing Preferences
zaphead
Thank you for replying. Unfortunately, the menu structure of my version does not match your description. The closest I've found to selecting units is by:
Options->Current Document Preferences->Units
I set these to "Inches" and it still displays in meters on my dimensioned drawing.
