settings in the Drawing Preference : mm & Architectural format
2 messages Options Options
otrott
dear LibreCAD user
one question regarding the settings:
main unit - milimeter
format : architectural
these two settings in the Drawing Preference  do not fit - in other words they do not get accepted!?
why is this so!?
i do not want to work with inch
Look forward to hear from you
regards otrott
Re: settings in the Drawing Preference : mm & Architectural format
Format Architectural is an us/imperial standard using inches and feet only. If you want to use metric units (mm, cm, m) then use Decimal or Architectural(metric), the latter with meters only.
