[solved] Insert text from file: empty rectangle instead of text
AnC
AnC
What should happend
Using insert text, and importing a 10 lines text from a text file, the text is shown inside the text menu windows. And then clicking on "OK", that should show (design) the entire text at the place targeted after a click somewhere on the design.
What happend
Instead of having the text shown on the design, there is only an empty rectangle.
question / help needed
I imagine, the problem comes from a question of "size of text" and "size of box" because, when I import a text with only 1 word, there isn't any problem.
So, what should I do ?
Re: Insert text from file: empty rectangle instead of text
AnC
AnC
Thanks dxli: it is the solution.
If an empty box appear instead of a wish text, it may be because the "draft" mode is enable. If draft mode is desable, then text appears.
