use case for Modify → Revert Direction
3 messages Options Options
I'm curious if anyone uses Modify → Revert Direction.
What is a use case?
Re: use case for Modify → Revert Direction
This is typically used for CAM, when the DXF file is used for tool path generation for CNC machines. Then it is necessary to define the direction the tool should move in the drawing.
There were a lot of happy user when it was implemented.
Thanks!
