378 degree circle
378 degree circle
Jake
I am doing sacred geometry drawings.  A 360-degree circle is divisible by 1, 2, 3, 4, 5, 6, 8, and 9, but not by 7.  A 378-degree circle can have seven 54 degree angles.  Can LibreCAD make a 378-degree circle?  If yes, how?
By the way, the Sine of 54 is 0.8090, 1/2 of a Fibonacci number.
Jake
Re: 378 degree circle
What is a 378-degree circle?
You can't set your own custom angular units system.
snowforest
In reply to this post by Jake
You are able to rotate and when doing so make multiple copies at every certain degree - not sure if that solves your problem because I don't know what a 378 degree circle is.
fa201
From a drafting perspective, 378° circle does not make sense.
If you are interested in having 7 slices of 54° then you can proceed as follows:
1/ create a 3 point arc choosing the center and radius
2/ click on rotate, choose the arc then the center. Start point is one tip of arc and the end of point is the other one.
3/ In the rotation dialog window: choose multiple and enter 7 then for the angle enter 54°.
Fabrice
Gary S
As dellus noted LC does not support custom angular units.  However, 360 / 378 will give you the degree measure of one segment of a circle divided into 378 segments (0.952380952 deg).  Multiply that by 378 divided by the number of sections to get the degrees.  e.g. 0.952380952 * (378 / 7 sections) = 0.952380952 * 54 = 51.428571408 deg for each of the 7 sections of a 378 segment circle.
It's not quite clear what your goal is. If you just want to divide a circle into seven equal parts, you may try the tool Plugins - Divide. Result:
