Angular dimension extra lines
kamaron
Hi all,
I am trying to use angular dimension and it adds extra lines on top of the angle I want to dimension.
The problem is that the extra added lines have my dimension layer properties even though I just want the typical dimension double arrow line and label.
Please have a look at it. The extra added lines are white in this case and the dashed lines are the angle.
I need only the dimension label and double arrow arc, not the extra white lines.
Any ideas?
Thanks
Re: Angular dimension extra lines
I fear there is no solution. As I have tried out, angular dimension does not react to all settings in the dimensions settings box. Otherwise you could set 'dimension extension line' at 'fixed length' and '0'. Probably it was considered not to be necessary as usually angular dimensions are placed between the relevant objects and so the dimensions extension lines would coincide with them. Furthermore the dimensions settings are valid for the whole drawing and can't be set extra for each dimension.
