Did you save the drawing after having changed the dimension settings from default to your settings? I can't think of an other reason for being reset after closing and reopening the drawing. Or you might have opened one of the back-up files instead (#,~).
Drawing in real size is the proper way.
BTW if you set General Scale to for instance 100 in your case, you can leave all other values to default. They will be adapted automatically behind the scenes.
