Can't dimension any mnore.
Ehpar
I am having the same problem as described in this thread. Dimensions
When I select horizontal or vertical dimension form the tool bar or the pull down menu it sets to linear. It worked fine for a long time then just started doing this in the middle of a drawing. I also lost the ability to pick an object by proximity and snap by proximity at the same time. I have to click right on an object line to select it now.
I have been using windows 10 since before I loaded LibreCAD and the program worked fine in the past until this evening. I tried uninstalling and reinstalling to no avail.
Any help would be greatly appreciated. Thanks!
Re: Can't dimension any mnore.
As un- and reinstall doesn't help, it might be some screwed up settings in the windows registry for LC are to blame, as these are not removed. You can do this manually, but that's for the more experienced users. Alternatively you could install the portable version from portableapps.com, as there these settings are stored within the app and so are always fresh with a new install.
