Ledger page format rotated in PDF Export
FRK
FRK
I have checked earlier threads on this topic with no resolution.
Current Drawing Preferences set to Ledger:Landscape (w: 17.008; h: 10.984)
Saved
Print Preview shows the drawing, and paper orientation correctly.
However, 'Export to PDF' changes paper orientation to Portrait, but the drawing is still in Landscape format.
If the Current Drawing Preference is changed to Portrait, then 'Export to PDF' gets corrected, but the Print Preview is incorrect.
Is this a bug, or am I missing some setting for 'Export to PDF'? If so, where?
LibreCAD version 2.0.8
OS: LinuxMint 17.2 Rafaela
Thank you.
FRK
Re: Ledger page format rotated in PDF Export
FRK
Export as PDF works fine with A3 page format, which is close in size to Ledger. But, Ledger rotates the page by 90 degrees during Export as PDF.
Here is a simple native dxf file that I created: test.dxf
Here is the PDF output of the same: test.pdf
Please let me know if there is an error on my part, or if this is a bug.
Thank you.
