I have just tried to compile LibreCAD on a LinuxCNC installation, which is based on the (admittedly rather old) Ubuntu 10.04 LTS distribution.
I have found the hint in common.pri about custom.pro containing CXX_CPP11_FLAG, but the compilation still fails. Here is what I did: rli@cncsim:~/devel$ git clone https://github.com/LibreCAD/LibreCAD.git Initialized empty Git repository in /home/rli/devel/LibreCAD/.git/ remote: Reusing existing pack: 28199, done. remote: Total 28199 (delta 0), reused 0 (delta 0) Receiving objects: 100% (28199/28199), 54.27 MiB | 3.60 MiB/s, done. Resolving deltas: 100% (21610/21610), done. rli@cncsim:~/devel$ cd LibreCAD/ rli@cncsim:~/devel/LibreCAD$ echo "CXX_CPP11_FLAG = -std=c++0x" > custom.pro rli@cncsim:~/devel/LibreCAD$ qmake librecad.pro rli@cncsim:~/devel/LibreCAD$ make cd libraries/ && /usr/bin/qmake /home/rli/devel/LibreCAD/libraries/libraries.pro -unix -o Makefile cd libraries/ && make -f Makefile make[1]: Betrete Verzeichnis '/home/rli/devel/LibreCAD/libraries' ... g++ -c -pipe -std=c++0x -g -O2 -Wall -W -D_REENTRANT -I/usr/include/muParser -DQC_APPKEY="/LibreCAD" -DQC_APPNAME="LibreCAD" -DQC_COMPANYNAME="LibreCAD" -DQC_COMPANYKEY="LibreCAD" -DQC_VERSION="master" -DQC_DELAYED_SPLASH_SCREEN=1 -DHAS_BOOST=1 -DQC_SCMREVISION="2.0.2-24-ga25e73a" -DQC_APPDIR="librecad" -DQINITIMAGES_LIBRECAD=qInitImages_librecad -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++ -I. -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtGui -I/usr/include/qt4/QtXml -I/usr/include/qt4/QtSql -I/usr/include/qt4/QtSvg -I/usr/include/qt4 -I/usr/include/qt4/QtHelp -I/usr/include -I../../libraries/libdxfrw/src -I../../libraries/jwwlib/src -Icmd -Ilib/actions -Ilib/creation -Ilib/debug -Ilib/engine -Ilib/fileio -Ilib/filters -Ilib/gui -Ilib/information -Ilib/math -Ilib/modification -Ilib/scripting -Iactions -Imain -Iplugins -Iui -Iui/forms -I../res -I../../generated/librecad/moc -I../../generated/librecad/ui -o ../../generated/librecad/obj/rs_entitycontainer.o lib/engine/rs_entitycontainer.cpp lib/engine/rs_entitycontainer.cpp: In member function ‘virtual void RS_EntityContainer::draw(RS_Painter*, RS_GraphicView*, double&)’: lib/engine/rs_entitycontainer.cpp:1892: error: expected primary-expression before ‘[’ token lib/engine/rs_entitycontainer.cpp:1892: error: expected primary-expression before ‘]’ token lib/engine/rs_entitycontainer.cpp:1892: error: expected primary-expression before ‘const’ lib/engine/rs_entitycontainer.cpp:1892: error: expected primary-expression before ‘const’ lib/engine/rs_entitycontainer.cpp:1892: error: expected unqualified-id before ‘bool’ lib/engine/rs_entitycontainer.cpp:1904: error: expected initializer before ‘:’ token lib/engine/rs_entitycontainer.cpp:1907: error: expected primary-expression before ‘}’ token lib/engine/rs_entitycontainer.cpp:1907: error: expected ‘;’ before ‘}’ token lib/engine/rs_entitycontainer.cpp:1907: error: expected primary-expression before ‘}’ token lib/engine/rs_entitycontainer.cpp:1907: error: expected ‘)’ before ‘}’ token lib/engine/rs_entitycontainer.cpp:1907: error: expected primary-expression before ‘}’ token lib/engine/rs_entitycontainer.cpp:1907: error: expected ‘;’ before ‘}’ token make[2]: *** [../../generated/librecad/obj/rs_entitycontainer.o] Fehler 1 make[2]: Verlasse Verzeichnis '/home/rli/devel/LibreCAD/librecad/src' make[1]: *** [sub-src-make_default] Fehler 2 make[1]: Verlasse Verzeichnis '/home/rli/devel/LibreCAD/librecad' make: *** [sub-librecad-make_default-ordered] Fehler 2 rli@cncsim:~/devel/LibreCAD$ I don't know if this is a specific C++11 syntax issue or if the compilation fails on more modern platforms too. Best regards, Robert |
your gcc version is too old.
you need gcc-4.7 or later |
In reply to this post by Effad
I have build sucessfully with Ubuntu 12.04, gcc 4.6, with latest source. Therefore I added the CXX_CPP11_FLAG variable.
The error is caused by the use of [] lambda function in line 1892. This is supported since gcc 4.5 and c++0x compiler switch. But I can't guarantee, that no other errors will arise with gcc 4.5. Regards Armin
Yes, looks like lambda is supported gcc-4.5 and up.
is it this compiler error due to "-std=c++11" being ignored by gcc <= 4.6?
Yes, -std=c++11 was added with gcc 4.7, earlier versions fail with this switch.
Because the actual Ubuntu 12.04LTS still use gcc 4.6, I did the custom.pro hack to replace it with -std=c++0x. I tried to use both switches, trusting the unknown switch is ignored by gcc, but with that combination all gcc versions failed. I've checked this with gcc 4.6 and 4.8. Regards Armin
Sorry, reading your question the 2nd time, I understood it
The compiler error isn't because of -std=c++11, Robert figured out how to set the correct -std=c++0x switch. But the gcc version on Ubuntu 10.04LTS is 4.1, which is definitely too old for LC code. Regards Armin
