Convert Dimensions from Inches to Feet
claytoncarney
I have a floorplan drawing (with dimensions) completed with Units of Inch. How can I convert dimension display to feet?
I saw a very old thread that mentioned using the Modify > Scale command, but could not find how to set the Isotropic scaling factor (searched the manual; no hits for isotropic). It would be very helpful to find a method to quickly switch dimension display units.
Any suggestions?
Re: Convert Dimensions from Inches to Feet
We should be able to support units.
Before that, you may try the menu:
Options > current drawing preferences> dimensions> text size & position> Length factor
For example, a factor of 25.4 should work for drawings created with inches to have mm dimensions.
Any suggestions?
claytoncarney
Excellent! Works like a charm. Thank you very much!
But be aware of that this method only manipulates the text in the dimensions, the drawing itself is still in inches. When you do some measuring, asking properties or similar, or adding new elements you will see this.
