I was working without problems on this simple drawing when issues arose: I can't select anything with the cursor, the only way to do it is using a crossing window from right to left or from left to right. When I try to select anything by touching it with the cursor, it is not selected, and the leader under the word "barrote" gets dotted (by the way, it is the only thing I can select directly with the cursor). Sometimes, but not always, when I draw a window from right to left, a "leader" appears (it is the mirror of the previously mentioned leader). I am using Librecad 2.2.1 on Mac IOS
placard.dxf High Sierra. Could you help? Thank you
