Hello Everyone,
I'm new user of LibreCAD, I like it very much. I used it manly to view .dxf and .dwg files, and
to dimension the contours I receive.
Is there a way (or some config file setting) to enable default zoom when opening files. I have to click Auto zoom every time I'm opening file.
Also I need to setup Current drawing preferences - Dimension every time, for linear precision and linear zeroes (Linear zeroes: remove left and right - is much more important for me).
Can this be fixed with templates maybe, or this have to be set for every document. Can this be overridden so to use some default view settings for all documents something like application default.
Can we turn off the warning for dwg files being experimental (do not show again).
Also I noticed small bug - it cannot open file with unicode char in filename on win 10 - not big deal.
Thank you very much for your help
