Dimension below part.
8 messages Options
Peter Easthope
Examples show a dimension on the upper edge of a polygon.
The length of the upper side of a rectangle for example.
How can the lower edge be dimensioned so that the dimension
line is below the figure rather than superimposed upon it?
Negative values for the extension line extension and offset don't help.
Thanks,                     ... Peter E.
Re: Dimension below part.
Do you mean like this one?
Peter Easthope
Nice.  Thanks,           ... Peter E.
Peter Easthope
In reply to this post by Peter Easthope
"Snap endpoints" or "Snap intersection" was constraining the location of the dimension.  With "Snap free" the location was unconstrained.  Documentation could mention that Snap can constrain the location of a dimension.                  ... Peter E.
I added: "Enable Free Snap along with Snap Endpoints."
as step one here: http://wiki.librecad.org/index.php/LibreCAD_users_Manual#Dimensions
Is that what you were thinking?
Peter Easthope
Definitely that helps.  Thanks.
Now a new question.  The menu here shows "Snap > Free" and "Snap > Endpoints".
Appears that when one is activated, the other is always deactivated.  In the
graphical display, only one of the menu items appears recessed.  Therefore,
what is meant by "Free Snap along with Snap Endpoints"?
That has been fixed recently. However, you would have to build from source code. It's about time for another Nightly build really, there has been a lot of improvements.
