I am just starting out learning Libre/cad and I expect I will run into a lot of problems as I go along. I will try not to burden this group too much but I do have a problem I cannot seem to work out. When I add dimensions to an object the number appears offset from the item being dimensioned, as it should, but the dimension line does not follow. The dimension line, complete with arrows, appears right on the line being measured. I have adjusted many of the parameters in "Current Drawing Preferences" drop down menu (offsets etc.) but nothing seems to work.
Any suggestions would be greatly appreciated.
Paul
