I have a serious dimensioning error in finishing up a drawing. It appears in two places, both on the radial dimension & the horizontal dimension as R=0.69 and the D= 1.38. Checking it under magnification using the numbers at the bottom I get the correct value of D= 2.75, also notice in the properties box I get the correct value of R= 1.375. That's two correct values and two erroneous errors.  Is there a fix for this? Can I delete the Radial error in the drawing & replace it using the M-text feature? Will this fix the dxf file?
 I'm about to send this to a shop that does 3-D printing. I can't afford a mistake here.
p.s. I'm working on the Printing problem too. I can live with that, as I can convert the dxf file to a Pdf file.
