		This would be an advanced feature, which LibreCAD doesn't have. Only if the invisible reference points of the dimension are moved too with the operation, the dimension will update. Like Stretch or Scale.
 Or you might manually move reference points, visible as tiny blue squares after selecting a dimension, by pulling them to a different spot, using snap.
