Edit DXF under LibreCad - Exported from solid works
busymind
Hello
I export from solidwork a DXF.
If I edit this dxf in libreCad the texts are not as per initial file. bellow the initial DXF exported
After opening the file with libreCad text are ok.
Open with edrawing 2017 or 2015 results files shown correctly
If I edit or just save under libreCad the DXF (under any version) the text appear like this
Bellow the initial DXF from SW
Draw1.DXF
and updated files save as
Untitled.dxf
All text are wrapped.
All users use edrawing for preview the cad files. editors are using librecad.
windows version LibreCad
Version: 2.1.3
Compiler: GNU GCC 4.9.1
Compiled on: Sep 23 2016
Qt Version: 5.4.1
Boost Version: 1.60.0
Re: Edit DXF under LibreCad - Exported from solid works
busymind
With winmerge I had identified the parameter that make the difference
If I change the 4.430266530722797 to 0.0 then the text is not wrapped.
preview after change the notes for revision
