Edit Properties does not change dimension properties
1 message Options
tigadad
Version: v2.2.1.2
Compiler: Clang 15.0.0
Compiled on: Jul 14 2025
Qt Version: 5.15.2
Boost Version: 1.88.0
System: macOS 10.15
I add 3 horizontal dimensions to my drawing. I want to change their properties to layer dims set colour to by layers. Dims layer is default to cyan.
Select the dim text highlights all parts, text, measurement line and end lines. Select properties and select layer dims then select colour by layer does not show dims colour; I have to manually select cyan. Applying shows only the text colour changed. To change the colour of the measurement line and end lines needs them each processed separately.
Selecting 3 dims, changing properties only changes the colour as above but only on the text to the first one highlighted.
