Printer prints white on paper and PDF
Next Topic
9 messages Options
RV14
When I try to print on paper or PDF it is blank. I have looked at previous posts and nothing I try seams to make a difference. I even uninstalled and reinstalled LibreCAD. Attached is the file.
14_Cut_Split_Label_V2_.dxf
Re: Printer prints white on paper and PDF
aman
Hello!
I use printpreview before printing. Good to correct margins etc.
RV14
Print preview shows up just fine but when printed it is blank.
aman
Which OS you use?
Which LibreCAD version?
In reply to this post by RV14
did you print to PDF first?
perepujal
Hi, I also had problems with this file, both in a devel build from some weeks ago and the 2.2.0 available in Debian Sid.
I am able to print it when I move the content closer to the 0,0 point.
HTH
Pere
RV14
Printing to a PDF or printer both are blank
RV14
In reply to this post by aman
I use Windows 10 and LibreCAD
Version: v2.2.1.1
Compiler: GNU GCC 12.2.0
Compiled on: Feb 18 2025
Qt Version: 5.15.2
Boost Version: 1.87.0
RV14
Moving the drawing closer to the 0,0 point worked I can now print.
Thanks for all the help.
