Editing vertical dimensions leaves both text versions
tigadad
Version: v2.2.1.2
Compiler: Clang 15.0.0
Compiled on: Jul 14 2025
Qt Version: 5.15.2
Boost Version: 1.88.0
System: macOS 10.15
Editing the text of a vertical dimension does not delete the original and leaves both a a shadow. It does not appear to happen with horizontal dimensions.
Re: Editing vertical dimensions leaves both text versions
I cannot reproduce with the latest 2.2.1 release candidate.
I tried with the release candidate build for macOS from here:
tigadad wrote
Version: v2.2.1.2
Qt Version: 5.15.2
System: macOS 10.15
tigadad
Thanks. I just downloaded the rc and it works fine.
Cheers.
tigadad
OOPS, I spoke too soon.
When I edit a dimension string it does not delete the original and I can't manually delete it.
Intermittently I can appear to cure it by re-editing the dimension but it re-appears when I save and restart the drawing.
tigadad
I have waited for a newer version before responding but the problem still exist. When I edit the text ion a dimension line it does not erase the original, it shows both versions. I cannot delete the original on it's own. It deletes bot. Horizontal or vertical does not matter.
Version: v2.2.1.3-2-g1598766fb
Compiler: Clang 17.0.0
Compiled on: Jan 11 2026
Qt Version: 5.15.2
Boost Version: 1.90.0
System: macOS 10.15
hi,
I still couldn't reproduce this issue.
Could create an issue at:
https://github.com/LibreCAD/LibreCAD/issues
since I'm not 100% sure about the bug behavior, please be detailed and exact in description of steps, and even better, with screenshots/export images.
Qt Version: 5.15.2
System: macOS 10.15
