Welcome huchipila!
Basically CNC's don't like complex curves, because the calculation of X/Y coordinates along the curve, in an acceptable resolution, is too expensive in the sense of computing time.
A circle or circular arc is much cheaper to compute using sine/cosine tables. An ellipse has different radii in each point of its circumference, that's probably what the shop meant.
You can try a simple trick and save the drawing in R12 format. On file save find the format drop down and select R12.
DXF R12 has no ELLIPSE entities and on save it is converted by
libdxfrw into a bunch of small straight line segments.
As I have some expertise in stone machining, this method might be not sufficient, because the line segments are not tangent. It possibly works when the cutout is ground/polished by hand afterwards.
Some post processors do the conversion on the fly by creating an approximation with circular arcs. The advantage with circular arcs is, that the result has a
G¹ Geometric Continuity like the ellipse.
An approximation for a quarter of the ellipse is sufficient and can be applied to the other quadrants too. A good approximation with acceptable deviation starts with 4 or 5 circular arcs per quarter. More arcs can reduce the deviation but also makes it more complex.
This avoids any angles because the contour is tangent overall, and it works fine for stone machining.
Sadly I don't know any simple method to draw this approximation by hand, with a reasonable level of deviation.
