LibreCAD - forum locked! please use https://discourse.librecad.org/ now
LibreCAD-dev
Search
everywhere
only in this topic
Advanced Search
Feature request: rotate by two lines
Previous Topic
Next Topic
Classic
List
Threaded
Locked
7 messages
arcol
Reply
Threaded
Hey,
Im a long term qcad user, I mainly use it for reprap related tasks (along with openscad).
I have one feature what I really miss from qcad:
Rotating is only possible in numeric numbers and not in reference by two lines. (like measuring angles).
So I always fear my rotating is not correct (as I can measure the degrees in degree unit, and not 0.1 degree unit).
Also the degree measurement tool should display at least 0.1 accuracy. (ex: 22.4 degrees)
Best,
Laszlo
eric.c.kangas
Reply
Threaded
Re: Feature request: rotate by two lines
I am also needing this option as well. I am working on a project that will require exact rotation between to reference lines.
Reply
Threaded
Have you tried modify->align?
Align moves and rotates using points as reference and if first base/target point is the same only rotate
eric.c.kangas
Reply
Threaded
I do not have the option align on my version of LibreCAD
Reply
Threaded
If you do not have align you can not use (is a plugin), but wath is your system and LC version ?
hsrai
Reply
Threaded
It looks that to use plugins, one need to compile / build LibreCAD; which we can't expect from all user.
Can we make use of plugins in easy manner?
H.S.Rai
H.S.Rai
eric.c.kangas
Reply
Threaded
In reply to
this post
by Rallaz
I am using Ubuntu 12.04, LibreCad Version: 1.0.1, SCM Revision: 1.0.0
Free forum by Nabble
Edit this page
