Freezes when expanded
potcharin
Hi all,
Recently I started using LibreCAD.
This is my first time using CAD, and I use it while studying.
I am writing a simple drawing, but it freezes when enlarged.
Even in Task Manager, neither CPU usage nor memory capacity is at the limit.
Do you know why it freezes?
(The attached image is a drawing I made in practice.)
simpleDrawing
freeze
pcData
change language from Japanese to English
Re: Freezes when expanded
There was an issue with construction layers, especially when their line type is not continuous.
That seems to be valid for you, if I saw it correct on the screenshot.
So the options are to switch off construction layers for zooming or update your LibreCAD version.
For Windows we have nightly builds where this issue is solved.
But the latest nightly build has some other issue with file save, so you'd better use LibreCAD-Installer-2.2.0-rc1-142-ge38b7088.exe for update.
It's a release candidate version and as stable as the version you use now.
potcharin
Thank you for the information freezes issue.
I learned very much.
I want to use 2.2.0-rc1-142-ge38b7088.exe.
