Thanks guys! Do you think you can do the same for the block list? (I mean having the green highlighted block)
Moreover, in order to empower the potetntial to LC, it would save a lot of time if it could be possible to have multiple selection for layers and blocks, with a "select all"/ "deselect all" option too.
What do you think? But I think this is a feature request.
I can give you immediately an example of the help that it would give this feature:
today I had to open a file with a lot of blocks, (believe me, they were really too many) and activate several layers to clean up that draw. I'm pretty sure that I'm not the only one having this kind of problems, especially if here there is someone that has to do with "proprietary" files.
Any opinion/suggest welcome
