Hatch density - darkness
PatrickNC
I have a square area I've filled with a hatch (ansi31). It's barely dark enough to be noticeable as hatched. Is there a way to make it darker? The fine lines are as close together as I would want, so maybe density is not the right word. The lines could be a little larger, but I haven't been able to enlarge them.
Ver 2.1.3
Windows 7
Patrick
Re: Hatch density - darkness
fa201
You can modify the density using the scale value of hatch pop-up window. for hatches, already done, use properties and click on the hatches then hatch pop-up window appears.
To make the lines larger, then you should change the line width of the layer holding the hatches.
Same if you want to change the color of hatches.
Fabrice
