Hatching
15 messages Options
Hatching
Bryon
Hi.
Name's Bryon
In the draw toolbar there is a group that includes; M/text Hatch Insert Images and points
The Hatch icon produces no results.
Trying a number of word combinations same story.
Whazzup?
Re: Hatching
Select the shape(s) to be hatched (must be perfectly closed contour), and close selection with Enter.
Or select objects first, (no Enter needed), then trigger the Hatch icon.
Re: Hatching
Bryon
Thanks for the response.
Did that as well as determined the "shape",which was created from a series of polylines, was completely "closed". All to no avail.
BTW, I'm coming from Autocad which I bought after asking if I could continue using it with Windows in "perpetuity". Stopped working with the very next Windows version that was released.
Anyone considering Autocad might want to re-think it. Now they want to sell you a "subscription" on a monthly charge basis.
Re: Hatching
Does the hatch settings box come up?
Maybe the hatching is too wide so it seems there is nothing.
Re: Hatching
RainerThe
Hello from Germany!
I'm new with librecad and just trying several options, to get used with it.
So, I also have problem with the hatching funktion.
Let me explain:
I draw a simple retangle
I mark the lines - they become up to a dashed line
I chose tool-box / hatching
a popup-window appears to chose some options about hatching - I chose "solid filling"
I confirm with OK
the popup-window disappears, lines chances to continues lines and that's it - nothing more happend!
Commandlline says: Hatch created successfully
What I'm doing wrong?
Thnaks for your support!
Re: Hatching
If you click into the hatched area, does it get highlighted? Then there must be something. Also try "Properties", what does it say? Try changing colour with "Attributes".
In the command line, after "Hatch created successfully", is the hatched area indicated?
Is the active layer different than the layer with the rectangle, and is switched invisible? Then you will not see the hatching until you switch it to visible.
Re: Hatching
RainerThe
Hi dellus, thanks for reply! I'll give my answers in your post:
dellus wrote
If you click into the hatched area, does it get highlighted? NO
Then there must be something. Also try "Properties", what does it say? For me it looks OK
In the command line, after "Hatch created successfully", is the hatched area indicated? NO
Is the active layer different than the layer with the rectangle, and is switched invisible? same layer, visible
I recorded my activities on libreCad. Hope it works and you could see, what I did! It's a link on my server!
https://pr498te.ddns.net/index.php/s/XznbW7PjCjs9XBW
Re: Hatching
See:
- https://forum.librecad.org/Hatch-problems-tp5709588.html
- https://dokuwiki.librecad.org/doku.php/usage:faq#my_drawing_had_some_hatches_how_can_i_see_them
Re: Hatching
RainerThe
Yeah, that's it! Creazy! Thanks a lot LordOfBikes!
You have disabled "View->Draft mode" ?
Re: Hatching
Ah, I should have seen that. How embarrassing for me. I am getting old.
Re: Hatching
RainerThe
dellus wrote
I am getting old.
Same for me!
Thank you for your support, dellus and LordOfBikes!!
Re: Hatching
emil_haller
In reply to this post by Bryon
I'm having a similar problem when hatching a closed spline.
Everything seems to work fine, the hatch dialogue appears, i choose "solid fill", the hatch shows up in the preview, I press Enter, the command line says "Hatch created successfully", yet I can't see the hatch.
Draft mode is disabled, so that can't be the issue. Also, I do the same thing with a rectangle or a circle within the same drawing and everything works fine.
Any idea what the issue could be? Any help/input would be greatly appreciated.
I'm using Version 2.2.0 on a Windows 10 machine.
Re: Hatching
Hatching spline contours just doesn't work in LibreCAD.
As a workaround you can explode the spline and select all the single entities, works.
Re: Hatching
emil_haller
Oh, ok, thanks for clearing that up! Will try the workaround.
Re: Hatching
We should allow hatching with SplinePoints, if there is no self-intersection.
All tools needed are there for SplinePoints:
Bonding boxes;
Intersections;
Line integrals;
