no main menu
5 messages Options Options
no main menu
NotBob11
Hi all
Just installed LibreCad onto Garuda Linux Dr460nized. When I start it, there is no main menu. As in File, Options, ...
I tried deleting the librecad.conf file in my ~/.conf/librecad directory, That did nothing. I tried using the alt+o and alt+f to see if that would open the menu up, but no.
Right clicking on the title bar does not provide a show menu clickbox.
Can anybody help me? Gonna check the Garuda WIKI to see if the problem lies there.
Thanks in advance
I never knew that!
Re: no main menu
aman
Hi and welcome!
You probably changed something off, Ctrl-I should bring status bar back, if you refer to that.
Re: no main menu
NotBob11
File  Options  Edit  View  Plugins  Tools  Widgets  Drawings  Help
The menu you have clicked on is the one missing. CTRL+i does show or hide the status bar, those shortcuts are working.
I installed LibreCad on Fedora, and the menu is there. Going to reinstall it here on Garuda, and hope for the best.
Thanks  for the tip, I do love my keyboard.
I never knew that!
Re: no main menu
Welcome NotBob11!
Possibly it's related with full screen. I don't know this Linux distro, but I think if it starts LibreCAD in full screen mode, the menu is hidden.
The LibreCAD shortcut to toggle full screen is F11, maybe Garuda has a different one.
Re: no main menu
NotBob11
In reply to this post by aman
Found the problem.
I am using Garuda Linux which uses arch repositories.
As it turns out, the arch repository version pacman retrieved for me has a problem with the main menu.
I removed LiberCad and the .config and .local user files. Then I installed it with flatpak and it works as expected.
Again, thanks everybody.
I never knew that!
