Welcome!
Why does the DWG import fail?
The support of DWG format by LibreCAD is basic. If the DWG import fails, you can convert from DWG to DXF format. Free converters are available on the web.
The DXF import process failed, why?
LibreCAD does not support all features of Autodesk DXF format. Currently, only the following DXF formats are supported: R12, R14, 2000, 2004 and 2007.
I copied the above text from the FAQ, links to that and other docs are at the top of the main page.
