How to add text to a drawing
6 messages Options Options
AussieModelEngr
Trying to add text to a drawing. I follow the instructions and put the text in the dialog box and click OK. I see the yellow reference lines and the outline of the text box but  I do not see the text. I left click once and right click once and then I only have the box outline without any text.
What am I not doing correctly?
Regards,
Aussie Model Engineer
Re: How to add text to a drawing
sp1der
Hi
Have you got the correct height?
Can you attach a test file?
AussieModelEngr
Gear_positions.dxf
Thank you for replying. My first time uploading a file so hope I have done so correctly. Since my initial post I have realized that the contents of the text boxes at the top actually print but I cannot see the contents on the screen and cannot see contents on the print preview; they just show up as 2 rectangular boxes.
Regards,
sp1der
Text is showing clearly for me on Windows.
What operating system are you using here?
I have attached a revision of your file, I have put the text on another layer (Text) in a Green colour, can you test this one out and see if it makes a difference.
Revision_-_Gear_Positions.dxf
Log in,'right click' on the file and choose save as to download it.
In reply to this post by AussieModelEngr
AussieModelEngr
Problem resolved. My thanks to both who replied. Disabling Draft Mode did the trick. I doubt that I would ever have found that on my own.
Regards,
