How to use libdxfrw?
9 messages Options
mandeep7
Hi all,
I am working to use libdxfrw library. I have gone through files
involving writing of a line to DXF file. I created an instance of
DRW_Line and set the values of the base point and second point of the
line.
DRW_Line line;
line.basePoint.x = 10;
line.basePoint.y = 20;
line.secPoint.x = 30;
line.secPoint.y = 30;
qDebug() << line.basePoint.x;
dxf->writeLine(&line);
However, I could not achieve it. I have also referred the "testcp"
the example given at SourceForge but it did not work either. The first
thing I want to achieve is to write a line to DXF file. Please help me
achieving this.
Mandeep Singh
Re: How to use libdxfrw?
mandeep7
R. van Twisk wrote
Mandeep,
here is an example https://github.com/rvt/dxfrwtest (we spoke on the LibreCAD IRC channel).
modify CMakeLists.txt because I quickly hacked it together.
Thanks ries,
I got this working.
R. van Twisk wrote
For your sample you gave me,
I would advice against trying to modify existing code when you are traying to understand something. It's usually better to start from 0 and learn from their then modifying existing code, change a lib and hope for the best...
Thank you for the advice. :)
Mandeep Singh
Kamalpreet
Various virtual functions have been included in  'ExampleWriter.h'. For an instance,
virtual void addLType(const DRW_LType &data) override {
Why do one need to include the functions that are not even considered to be used in a project?
Kamalpreet
Following the same example, I am trying to set the attributes of entities using variables.
Code for the same can be referred to at:
https://github.com/kamalpreetgrewal/textToDrawing/tree/test
In the file ExampleWriter.cpp,
On calling writeLine function (dxfW.writeLine(&b);) in addLine, it crashes (seg fault).
Can you help by pointing out my mistake.
Jasleen
In reply to this post by mandeep7
On 4 April 2016 at 17:16, mandeep7 [via LibreCAD]
<[hidden email]> wrote:
> Hi all,
@ mandeep, kamal
can you come tomorrow? I want to know the work you are doing. May I
involve in it?
Jasleen Kaur
jasleen7956.wordpress.com
mandeep7
R. van Twisk wrote
What are you trying to accomplish?
Thank you. Now got it working.
Please see if I am doing it right.
https://gitlab.com/greatdeveloper/BuildD/blob/master/EntityWriter.cpp
Couldn't make Polyline work for me. Can you please tell what parameters I am missing for this entity that need to be set.
Mandeep Singh
