ICONS FOR V3
7 messages Options
ICONS FOR V3
MrCAD
I would like to share these icons for LibreCAD Version 3 as a suggestion.
Please share your thoughts with the comments.
I am sharing the dxf file within this post to modify or edit the dimension according to ICON size for the User Interface.
icon.dxf
Re: ICONS FOR V3
arquisa
I like the shape of the icons, it's cool, but I think they would stand out more if the background is dark,
Re: ICONS FOR V3
fa201
For the 3 point circle, if the function allows to use 3 randomly positionned points then I suggest that the icon shows points for which the center is not aligned with 2 of the 3 points.
Fabrice
Re: ICONS FOR V3
In reply to this post by MrCAD
Your icons look great as they are shown here, large and with white background. But you have to consider in reality they are shown much smaller, size differs depending on screen size/resolution and also on the tab, they get blurred, and the background colour mostly will be different. The black rims around coloured elements in the present icons don't give a neat look, but help keeping them readable under these circumstances.
Dashed lines especially tend to look very blurry when rendered small. Also I think elements not saying really something, just added for looking good, should be avoided.
Using a dark variant of the chosen icon colour instead of black I find an interesting approach worth to be explored further. This dampens the harsh contrast but still helps readability.
When former developer ravas made the advanced more configurable user interface, he incorporated a possibility to change the icon colour to your likening. I have never tried to find out how this works and experiment with it. But the use of this feature should be in the mind also.
Icons shown in Win XP on my 1200 x 1920 display
Your icons at a comparable size
Same with grey background
Here the link to the present LibreCAD svg icons. You might use these as a template for your own experiments. The grid size used was according to a proposal by ravas, may be that's not optimal, a graphic's design crack may know better.
https://github.com/LibreCAD/Resources/tree/master/librecad/icons
I hope I'm not discouraging
Re: ICONS FOR V3
zamtmn
>>icon.dxf
this file created with librecad? cannot open with autocad
Re: ICONS FOR V3
MrCAD
No worries. It can be understand and thanks to draw my attention.
Re: ICONS FOR V3
luko
Thanks for the improvements to the icon set! I would like to suggest another change to the snap icons.
The current version of snap center and middle represent the same line and circle, and the very subtle difference is only the position of one green dot. When the two green dots are close, it is middle, when the two dots are far, it is center. I find this confusing and because there is no mnemonic that can be associated to that, I need to observe both and think for a whole second before I can tell which icon to click.
I would suggest to keep only the curved line for center, and the straight line for middle. See the image  top row is the current version, the bottom row is a modified version (just a bitmap screenshot edit), with fewer but more clear visual clues.
I believe the original version intended to cover edge cases where straight lines have a "center", and circles a "middle", but I think the ability to identify which is which at first glance, and therefore create a mnemonic, is more important than including all the edge cases in a single icon.
