Import Error: Error reading DXF/DWG sections
13 messages Options
ArlianObsidian
Hello all,
I'm new to LibreCAD, so please excuse my ignorance when it comes to all the functions in this program. I have been using AutoCAD for years, but my license is up and I cannot sustain the cost. I only just learned about LibreCAD and I'm very excited to start using this program!
I am having difficulty importing my previous projects from AutoCAD. I exported my projects to .dwf format (though it doesn't appear that I can do anything with those. Next I used an online converter to convert my .dwg files to .dxf format. I can open the .dxf files in AutoCAD still (though I lost my paper space layouts, but that's not such a big deal).
When I attempt to open my .dxf files in LibreCAD, however, I receive the following prompt:
Error Message
You can see in my screen snip that my project is visible behind the error message. When I select "OK," that all goes away. I've tried zooming in, and zooming out, as has been suggested in other forum threads. My project is not there, and the application header does not display my project name.
Application Heading
Since AutoCAD is the only other CAD software I've ever used, and I am so new to LibreCAD, I am really at a loss on what to do next. I have another 25 days before my AutoCAD license expires, and I'm in a bit of a state of panic. I greatly appreciate any help from the LibreCAD community! Thanks in advance.
-Arlian
1105_S_50th_Ave.dwg
1105_S_50th_Ave.dxf
Re: Import Error: Error reading DXF/DWG sections
Your dxf file opens for me with no issues in LibreCAD 2.1.3 as well as in 2.2.0 rc4 on Win XP.
I don't get the import error message.
When I try to open the dwg is says unsupported dwg/dxf file version.
Maybe you get something mixed up when trying to open both dwg and dxf. Maybe the dxf is still open in the background. Go to Drawings - Tab mode to see if it is still there.
There was a fix recently, which solved exact this message.
So when the cause is the same, you should ensure that you use latest 2.2.0-rc4.
See Help -> About and update if your version is not 2.2.0-rc4.
ArlianObsidian
Thanks! I have the latest version installed, so I'm not sure why it didn't work originally. By some strange magic, a new .dxf file appeared with a pound sign at the front of the file name. That one worked no problem! (Though I have no idea where it came from.) I converted a larger project to .dxf, and it also opened in LibreCAD. I don't have my paper-space layouts, but I'm not as worried about that (and maybe that's just a limitation of LibreCAD that I'll come to learn).
I have noticed, however, that my larger project is all screwy. One of the layers went bonkers and looks a total mess. It'll be easy for me to clean up, and the important details all loaded correctly. Anyway, I'm not sure how or why, but it appears I'll be able to move on from here. Thanks for all your input!! I really appreciate it. :)
Rod
Rod
I have the same issue. I thought it might be a ACAD version issue so I tried saving the DXF file as V2000. But I get the same response. The file appears to almost fully load on the screen but with the following error message.
"Important Error Message:error reading DXF/DWG sections"
Once I press OK, the file load stops, and the screen goes blank.
I just downloaded the latest version, so I don't think it's a version issue with Libracad.
Unfortunately my file never changed to X...:(
Any help much appreciated!
Rod
Rod
I take it back. About 10 minutes later I noticed a copy of my file marked "X(my file name).dxf, which I was able to open.
Thank you X!
Rod
Rod
I hacked around with it for way too long and almost by accident found the only way to get it to display text was to explode the text box. No idea why. It's a work around but not ideal as working with exploded text is painful.
Text Box
Exploded Text Box
Selected Exploded text box
Note the exploded text is individual elements. Not ideal but better than a text box.
San Jay
HI Dellus,
SOrry but you have another novice seeking help !
I converted a .DWG file to .DFX (size about 500MB) using "TEIGHA" convertor and ASCII DFX Option there.
When I import the DFX File ( it asks "Image" or Block" - I presume i have to import it as a Block), I get a message " Cannot Open the file...... ".
The DXF file is good on AutoCAD viewer.
My version is 2.1.3 .
DO I have to use some different settings or is the file size too big?
WOuld appreciate some help as my Project is held up and I cannot sustain the cost of AUTO CAD License .
Hoping for some help from you.
Regards
Jay
Why do you "import" the file? This means to import a drawing into an existing one. Thus the question for "Image", if you want to place a bitmap image like a photo or scan in a drawing. Just open the dxf file.
The latest dxf file version LibreCAD can open is dxf 2007.
Yes, 500MB is really heavy, this might be the reason. Does it contain 3d elements? How large is the original dwg? Can you provide it here?
You may also try to use the current LibreCAD V2.2.0 rc4 development version. Much improved and as stable as 2.1.3.
San Jay
Hi Thank you for the revert - if i open the DWG directly, it gives me a message "experimental;save your work first...."!! Screen shot attached
if I click OK, it says "Check its permissions and existence . I have tried changing the DWG to 2004 and 2000 AUTOCAD versions also - nothing works
Am I missing something fundamental here ?
I am on Windows10Pro.
Had good hopes on LibreCAD for my work...
I am trying to attach the file here - hope it goes through
Unfortunately your file has not gone through.
As Lord Of Bikes says in an earlier post:"There was a fix recently, which solved exact this message.
So when the cause is the same, you should ensure that you use latest 2.2.0-rc4." So best update first.
Maybe some clues here:https://forum.librecad.org/Can-t-open-dxf-and-dxf-files-td5721091.html
Could it be a problem with OneDrive?
Woody250
In reply to this post by ArlianObsidian
I am continuing to have problems opening an AutoCad Lite 2000 DXF file with LibreCAD. I am also new to Libre and just downloaded it so hopefully it is the newest version of Libre?
sand1024
well, actually the support of DWG format is quite limited, so it might be practical first try to convert the file to DXF (either via AutoCAD or external services) and try to open it.
Can you attach the file with opening problems?
