Import multi sheet dxf file
3 messages Options Options
Thomas Idebrant
When I try to import a .DXF file with several drawing sheets in it, Librecad make all sheets to one.
Re: Import multi sheet dxf file
LibreCAD doesn't have multi sheet capability. Try to sort the drawing by switching layers on and off. If you are lucky the different sheets use different layers. You then also can delete the unwanted layers and resave under a new name, for each sheet.
Thomas Idebrant
Ok! Thank you. Then Librecad is useless for me. I handle a lot of .dxf files that are multisheet. :(
